LSSV Owners, post info and pictures of your truck.
rtk
449
Lockport N.Y.
What a nice MV ! You did a great job .I followed your thread on this site . Why do suppose the military surplussed it to begin with ? How many miles on it now and how has it been running ? bob k
roadkill150
North Coast, CA
2002 lssv
A few Pictures of my truck. It's a 2002 LSSV 2500HD, Crew Cab, 4X4, 6.6L Duramax Turbo Diesel with Allison Transmissionwith 33k miles on the clock when i purchased it. I think it is also the last year of the Duramaxes that did not have smog equipment on it. Also it was equipped with the front and rear Warn multi-mount winch setup. If anyone can look at the build options and tell me what goodies it came with I'd appreciate it! Sadly, I am considering parting with it as I have too many pickups. We will see!
IMAG0090.jpgIMAG0083.jpgjumpstarter.jpguploadfromtaptalk1368046480158.jpguploadfromtaptalk1368046463628.jpguploadfromtaptalk1368046440487.jpguploadfromtaptalk1367792399360.jpguploadfromtaptalk1367792356863.jpguploadfromtaptalk1367792083708.jpguploadfromtaptalk1367792015818.jpg
camoyj7
19
wonder lake IL
You have one recall still open it's. Product Safety Recall
N040007
04007
TAILGATE SUPPORT CABLE
09/17/2004
Open
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
12I - GRAPHITE INTERIOR TRIM
12V - GRAPHITE VINYL
1SA - BASE DECOR INCLUDES: * 40/20/40 SEATING * AM/FM STEREO,SEEK/SCAN,CLOCK
41U - ONYX BLACK
5Z5 - DELETE HUBCAPS SEO
6GL - FRT LH COMPUTER SEL SUSP
7GL - FRT RH COMPUTER SEL SUSP
8F2 - DELETE ORNAMENTATION
8X5 - GENERATOR 105 AMP DUAL
AE7 - 40/20/40 SPLIT BENCH RECLINING FRONT SEAT
AM7 - FOLDING REAR SEAT
B71 - WHEEL OPENING FLARES
BAG - EXPORT PARTS PACKAGE
C60 - AIR CONDITIONING WITH AIR FILTRATION SYSTEM
C6W - GVWR: 4173 KGS (9200 LBS)
CMD - ASSEMBLY PLANT - FLINT, MI
CW6 - COUNTRY - GUAM
DE2 - EXT MANUAL CTRL FOLDING MIRRORS
E2C - RAPID DELIVERY SYSTEM PROC OPT
E63 - FLEETSIDE BODY EQUIPMENT, PUBX
EXP - EXPORT PROCESSING OPTION
FE9 - FEDERAL EMISSION CERTIFICATION
FT2 - ARM TORS SPRING ADJ.
FT3 - ARM TORS SPRING ADJ.
G80 - LOCKING REAR DIFFERENTIAL
GT4 - 3.73 REAR AXLE RATIO
HVY - IDEN 2 INCH BODY RAISE,HD MODEL
JH6 - 4 WHEEL POWER DISC BRAKES, HD
K05 - ENGINE BLOCK HEATER
K47 - HIGH CAPACITY AIR CLEANER
KC4 - ENGINE OIL COOLING SYSTEM
KNP - H.D. TRANSMISSION COOLING SYS
KUP - THROTTLE CONTROL ELECTRONIC
LB7 - 6.6L DURAMAX DIESEL
M74 - 5 SPEED AUTO TRANS, ALLISON
NF2 - FEDERAL EMISSION SYSTEM TIER 1
NP2 - MANUAL SHIFT TRANSFER CASE
NPL - NAME PLATE DELETE
NZZ - OFF-ROAD SKID PLATE PACKAGE
QIW - TIRE:LT245/75R16/E BL OOR R/PE ST TL
R6V - PROCESSING CODE - APO
R9Q - PROCESSING CODE - FLEET/GOV'T
R9Z - POMS EXPEDITE-SOLD ORDERS
SLL - SOLD ORDERS
TQ3 - BATTERY 770 CCA (DUAL)
UM7 - AM/FM STEREO W/4 SPEAKERS
UQ5 - DOOR MTD. DUAL FRT SPKR SYSTEM
UY7 - WIRING HARNESS TRUCK TRAILER
V22 - DELUXE FRONT GRILLE
V43 - PAINTED REAR STEP BUMPER
V73 - US/CANADA VEHICLE STATEMENT
VC7 - PRICE LABEL - GUAM
VG3 - FRONT DELUXE CHROMED BUMPER
VPH - EXPORT VEHICLE PREPARATION
VR4 - TRAILER HITCH WT DIST PLATFORM
VXS - COMPLETE VEHICLE LABEL
X88 - CHEVROLET NAME PLATE
XGK - TIRE:LT245/75R16/E BL OOR R/PE ST
YD3 - AXLE BASE EQUIP PROECESSING OPT
YD6 - BASE RR SPRING PROCESSING OPT
YGK - LT245/75R16/E OOR BW TIRES-REAR
YK6 - IDENTIFICATION SEO (POMS ONLY)
Z82 - TRAILERING SPECIAL EQUIPMENT INCLUDES: * TRAILER HITCH PLATFORM
Z85 - HEAVY DUTY SUSPENSION
ZE5 - BASE TRIM IDENT PROCESSING OPT
ZGK - TIRE:LT245/75R16/E BL OOR R/PE ST
ZY1 - SOLID PAINT
M1075
Oklahoma City
I think James (M1075) is the only one left.
I have a 2005 LSSV, purchased from 63foxtrot and also formerly owned by the late DJfreema. RIP sir. Here are some pictures taken in the last year or so that I have owned it. I removed the troop seats, added HMMWV wheels with 33" tires, and added nFab 6-gun step rails. I would like to do a few more mods as time and $$$ allow.
This is my favorite MV. It is a pleasure to drive and is very useful. It is the only one I have ever owned with AIR CONDITIONING, FM radio, and latch system for the kids' car seats. :D
camoyj7
19
wonder lake IL
If any one else wants there truck build post the last 8 numbers of the vin and I can run it and give you the options and if there is any recalls on it.
HETvet
Bedford, texas
All the duramax trucks have a 14 bolt rear and independent front. Also all have a G80 rear end. The most common gear ratio is the 3.73 (rpo code gt5) or 4.10 ( rpo code gt4 I believe). All the Alison transmissions up until 06 were 5 speeds. The emissions weren't in place until 07-08. The LB7 has Internal Injectors that like to leak. When the LLY came out, it had external injectors and a VGT turbo. As I ha en discussed in other threads, the LLY had heat issues. The LBZ is the go duramax engine when it comes to power. Last year of no emissions and most of the other issues sorted out.
If there is enough interest I'll post power modifications for each engine that are worth while/most bang for your buck.
