- 333
- 261
- 63
- Denver, Colorado
Need some help from the Deuce Gurus please...
The lube in my M275's 5-Speed Spicer is foaming. Not just a little, I'm talking some serious froth here. Subsequently, shifting seems to get tougher while driving as the lube gets churned, and then gets easier again when it sits (overnight) and has had some time to settle the bubbles out. Previous owner says it's straight 40w motor oil. The lube level is within spec, about 1/2" below fill-plug level. I don't believe the lube is water-contaminated because it's amber/clear and not milky.
Seems obvious the lube has to be replaced, and I've read that 30w, 40w, or 50w non-detergent motor oil is better than GL-5, but my questions are; have any of you had the same problem? did you figure out what caused the fresh-looking lube to foam? and what brand/grade/weight/type of lube cured it?
Thanks in advance for your replies,
MN
MN
