reaper556
- 3
- 18
- HOCKLEY, TX
I was greasing my 1028 today and finally went and purchased a needle nozzle so I could get the fitting on the constant velocity joint near the tcase. The lube order if im looking at it right shows a fitting for the front prop shaft slip joint near the ujoint closet to the front diff.
Is this fitting under the boot?
