jimm1009
- 71
- 48
- Louisville, KY
I would like to hear from the owner / operators of the Multifuel engines that use the Lucas additive in their oil and also in their fuel systems too.
I was at the local NAPA store and another truck owner came in and he swears by the engine oil additive for his diesels but they are more modern engines.
The instructions say that you can add up to a maximum of 20% capacity in this additive but that is definetly too much for an engine that has never seen anything but 30 wt. all it's life. My engine is a 1986 and no overhauls to date.
It has no leaks and a very minor seep currently so I do not want to induce any leaks either.
As a side note the label says it is also very good for transmissions and transfer cases too.
I believe in baby steps when it comes to additives so.....???
Can anyone that uses this stuff comment on the method that they used for slowly introducing this to their "baby"?
Thanks in advance.
jimm1009
Thanks in advance.
jimm1009
