lucky me
FreightTrain
Banned
2,730
13
Gadsden,Al
Nice,heat,Airshift,Straight hardtop,Supersingle radials,Great condition,Ether start.Now,what is that extra switch below the start assist switch under the dash?Didn't the ether kits just reuse the old Flame heater switch?
1,808
Ether start switch did replace the flame heater switch. The other switch looks like the fan high low switch.
Coveralls
Osceola, IN.
Kipman, you will appreciate those Xls on the country roads this winter. I had the same seat cushion on my first deuce. You might wand to add some extra padding as you start to go numb after a couple hrs. behind the wheel. Looks real good.
kipman
15
Lancaster Ohio
euc cleared 12/24/07, just got a BIG gift from santa, when I previewed the truck the batteries were dead, what are the best and cheapest to replace them??
FreightTrain
Banned
2,730
13
Gadsden,Al
well,I ran MM on 39.95 walmart car batteries.I filled the voids with cut up 2x4s.You don't need the factory type batteries to run a deuce.There have been people that don't run batteries in their truck.They rig up a box with a pair of lawnmower batteries and use that to slave off the truck then disconnect the battery box.All you need batteries for is the starter.After it is running the alternator will run the truck.Now if you want to replace them with correct fitting batteries.6TLs.They are about $150 each.
