Lug Nut torque on M35
doghead
4 Star General /Moderator
1,193
NY
search the forum?
doghead
1,193
NY
rsh253
Fort Mill, South Carolina
Hey Neil,
If you need to buy the Budd wrench or sockets for the lug nuts, let me know & I'll let you know where I bought mine.
My rattle gun is for cars & is too small. I loosen & torque the lug nuts with a budd wrench & length of pipe. I figure I can get pretty close to the right torque that way.
-Russ
maddawg308
821
Appomattox, VA
I have a geared lug nut wrench and I just lean my full weight on the bar to tighten it up, it's seemed to work out so far.
DanMartin
17
Hillsboro, Oregon (USA)
I use a big 1" impact wrench and a torque stick to get the torque right. They run about $75.00 each and are a lot less hassle than a torque wrench to get them just right (basically with a TS you hit the trigger on the impact until the socket stops moving and you're done).
http://www.torquestick.com/
Remember that on the budd duals, the inner (cap) and outer (bolt) torques are different.
neilhendrix
Reidsville N.C.
Thanks for ALL the info . Much help indeed. I had to use a torque mulitpier to get lugs loose today. Now I know this was way to much. putting them back I had my 1/2 inch drive on 250# and wouldn`t click. I used an impact wrench with a full load of air on the compressor. My I W is supose to go up to 350#. I think I `ve got it .
Thanks Neil
chipola
vancleave,ms
watch your torque, i 've got one now some lugnut put on . the nut wrung the threads off on stud . time to replace whole hub once i cut off old nuts. dud
KaiserM109
SE Aurora, CO
I need to look up the same info, so thanks for posting it.
Something my dad taught me that has made a lot of sense since then is that it is harder to get a nut off than to put it on. Don't believe that? It has to do with 'starting friction'. It takes a larger amount of force to get something moving than to keep it moving because of 'starting friction'. This means, just to throw some numbers at it, if you are applying 50 ft lb when you turn the nut around and stop, it will probably take 55 to get it started again.
If you put all you have into tightening a nut, you will be in trouble when it is time to take it off.
Another thing, look at the letter stamped on the end of the stud before you start cranking. I know, I know, "Left is always left and right is always right." My M37 in the Army had had the brake drums switched diagonally (they are interchangable front-to-back) so that I had right hand lugs on both sides of the back and left on both sides of the front.
Also, someone might have replaced a stud with the wrong one.
Arlyn
PS ' Just read the post: "400 to 450" !!?? No wonder the tire busters in the motor pool were always big guys!!
