Lug nuts damaging the rims.
erasedhammer
56
Maryland
So went to get my tires balanced and the mechanic at Les Schwab told be I should replace my wheels because the lug nuts have dug into them that they have bored out part of the tapered edge. He said that they could back off on the highway. The wheel in question has never had any issues with a year of ownership by me, so knock on wood they seem fine.
Is this really the case? If the lug nuts have been torqued down too hard too many times by the military and have carved out the tapered edge on the rim do they really need replacing?
juanprado
2,740
Metairie/La (N'awlins)
Could be just the opposite of loose lug nuts and the wheel wallowing out the hole as it had play. Could also be other symptoms of driveline and bearings.
someoldmoose
Lancaster, PA
Sounds like they want to sell you wheels. Yes, this can happen but it requires ridiculous over-torquing (no one EVER tightens lug nuts with an impact gun, right ?) many times (motor pools always use a torque wrench, right ?). Do the nuts allow you to SEE any of the tapered seat on the wheel when properly torqued or is any galled metal visible around the edge of same? If yes, replace the wheels(s) that do so. If no, thank your service technician for bringing this to your attention and find another tire service provider,
erasedhammer
56
Maryland
On some of the edges bare metal is very visible. But on others it's completely fine.
someoldmoose
Lancaster, PA
Well then, I already advised you what to do. Use the information at your own discretion.
If you doubt their safety, replace them AND replace the lug nuts also. I would also recommend replacing the affected studs as they were overtorqued also. It's a system. All items were involved.
Karl kostman
848
Fargo ND
replace anything that looks like a safety issue and one thing I started doing on my trucks years ago is put a drop of oil on the lugnut before you torque it down on the stud!
Karl
someoldmoose
Lancaster, PA
Karl kostman, one drop won't hurt but I recommend either nothing ( clean and dry threads ) or ARP - 100-9909 Ultra Torque. The ARP compound offers a slight anti-seize capabilty as well as allowing accurate torque. Highly recommend for alloy wheels on anything (including in the seat area of the wheel and nut / bolt). And, as always, use a TORQUE WRENCH.
ari
dacula Ga
I dont see how a hmmwv lug can back out on its own since they maintain a crap load of tension all the way off. its hard enough to take em off with a lug wrench
