LVS Wabco air dryer trouble shooting
tcody
Illinois
I need some trouble shooting help for a MK48 air dryer. The LVS is having trouble airing up. During the loading cycle the purge valve is dumping air making getting the pressure up hard. It looks like a Wabco super saver twin model. Is it likely just a problem with the purge valve or could it be something up stream. Anyone got the part numbers for the drier, the purge valve and the dessicant canisters.
Regards
Cody
73m819
315
gainesville, ga.
Sounds like dirt in the valve or a broke closer spring, because the valve is ONLY designed to open AFTER full operating pressure is reached
tcody
Illinois
Ron - thanks. I think I will take apart the valve tomorrow and clean it/check the spring and see what happens.
Regards,
Cody
