m-1008 bump stop specifications
sweetk30
horseheads,ny 14845
I am looking for stock m-1008 1ton truck bump stop specs .
as in the front suspension with stock leafs installed no lift kits .
there is the center over axle bump stop . inches off pad on ubolt top plate ____ "
there is a pinion snubber pass side for the diff . inches off bracket its bolted to and down to diff pad ____ "
and last is the rear bumpers on the frame rails just infront of the shackles under the firewall . inches off frame were it bolts down to leaf spring ___ "
and if your at it whats the rear axle bump stop specs ? bracket bump pad bolts to down to axle tube ___ "
thanks for the help guys :-D
cucvrus
10,076
Jonestown Pennsylvania
there is the center over axle bump stop . inches off pad on ubolt top plate ____ "1 1/2"
there is a pinion snubber pass side for the diff . inches off bracket its bolted to and down to diff pad ____ "2 3/4"
and last is the rear bumpers on the frame rails just infront of the shackles under the firewall . inches off frame were it bolts down to leaf spring ___ " 1 1/4"
and if your at it whats the rear axle bump stop specs ? bracket bump pad bolts to down to axle tube ___ "5 3/4"
I hope that helps. I always feel like a know it all and balk at answering questions. But I know how you feel. I have asked several questions on this site and got no answer. I just solved the issue myself. Thank you for looking and have a nice day. I hope I helped you out stock truck empty full of fuel and stock M1008 LT 235/85R16 tires on stock wheels.
