M 1008 Rear Yoke Replacement Part Numbers
usmcpatriot
14
Bumpass, VA
So, i tried to replace rear seal driveshaft yoke seal, it was leaking, only to find that the nuts where frozen. Tried everything everyone else tries to unfreeze the nuts. to no avail. So decide to cut the nuts off and the straps with the nuts. Played hell to replace parts OEM. Decided that being I had the shaft down, replace the front seal by the transfer case which was leaking also, parts easy to find just the pain in butt to find the parts. And this is what I found. Please see pictures. Hopes this helps anyone having problems like I did.
