mijon
- 0
- 0
- Fenton, MI.
Hello Green Community,
I have 86 M 1008 that's been giving me some tranny Issues. Any Ideas/ Help would be greatly appreciated!!
Explanation of Problem:
-When I first start driving the truck it shifts into all gears fine and just as it usually should. However, when I get about 20 miles on her, it will not shift into 3rd gear. Or it will slip into 3rd gear after driving in 2nd for about a mile or so. I followed the TM procedure ( see below) and everything checks out. The vacuum houses are tight and clean and I just changed the Transmission Module. Problem still persists.
Before I get into rebuilding the tranny . I was wondering if you guys could think of any other trouble shouting ideas?? The truck has only 57,000 miles on it. Ive used it as a plow truck / work truck. But it seems like I shouldn't be having these Transmission issues with that low of miles??
Please let me know if you need any other information and thanks for your time !!
60. FIRST AND SECOND SPEEDS
ONLY; NO 2-3 SHIFT
Step
1. Check tailpipe, muffler, exhaust manifolds, and exhaust pipe for
restrictions. (Clear any restrictions)
Step
2. Check for damaged or loose vacuum hoses. Remove, clean, and inspect vacuum
modulator assembly and modulator valve. (See paragraph 5-3)
Step
3. Remove, disassemble, clean, and inspect governor assembly. 5-5)
Step
4. Remove, disassemble, clean, and inspect transmission control (See paragraph
5-7)
Step
5. Remove, disassemble, clean, and inspect direct clutch assembly,
Step
6. Remove, disassemble, clean, and inspect front servo assembly (see paragraph
5-1 O) and rear servo assembly (see paragraph 5-9).
ONLY; NO 2-3 SHIFT
Step
Step
Step
Step
5-7)
Step
Step
