M-1009 Speedometer face plate problem
Lagers4myhead
Valdez Ak
I learned that it is a bad idea to take the gauge cluster apart in my M-1009. I was trying to get to the bulbs and the face plate of the speedometer fell off leaving a tral of wire to the needle and looked like a broken tape measurer. Of course after this happened i went and read the tech manual and I realize I should have taken the gauge cluster apart but like I said, I learned something. Has this happened to anyone else? Can I wind the wire back up? How bad is this?
319
Lieutenant
58
Michigan
Bad, I think this is the first time it's happened. You need to go buy a new one or go to a salvage yard and pick up a used one.
HAWKMAN
N.E. P.A.
If you can get it back together it will never be the same, your speedo will be off. These things are assembled by machines so not likely to get it back perfect by hand. If you can't get yours in one piece and can't find one close I have them available, PM me if you need.
