BigBlackTurd
- 0
- 1
- Deer, AR
Hey guys I just bought this m-1010 a couple weeks ago. And I'm having problems with the charging system. The front battery goes dead while driving. I have checked for stuck relays or anything that could be draining the battery, but can't find anything. Today I looked at the technical manuals. And using the troubleshooting chart for the charging system I found a diode that was burnt and in pieces that is inline between current/voltage regulator terminal "A" and the current/voltage relay terminal "IGN". It's a brown to yellow wire. The top alternator shows .5 volts across "-" and "+" terminals and 8 volts off the voltage regulator. The gauge in the truck stays in the green when the truck is running, and the 2nd battery checks 28 volt at idle. The 1st battery checks 12.7 after I charge it manually and will slowly drop.
Where can I get the Diode that is burnt up?
Need help please
Thanks Brad
Need help please
Thanks Brad
