M-1010 update...flex.
225
edmonton ,alberta
opened up the lower corners of the front fenders a bit,and took an inch of the back.i can now work the chasis a little more.
Something is limiting front travel,however.perhaps the front shocks are limited in up-travel due to the crappy factory mounts.the front spring rate is definitely too stiff.
edmonton ,alberta
yah...
for sure i thought of that...several people (local hard core offroaders) sugested the very same...remove it!
Then several others(local "former" hard core offroaders...older and wiser) sugested that leaving it in place would forestall problems with death wobble.
So...tonight i'll experiment.bar is off,and saved for re-install if required,with a new set of urethane bushings waiting to see if theres trouble.
Am also going to aquire the parts for crossover steering.have the new steering box already.also aquired the range box of an np-203 and three np205's picked up for cheap.will install a doubler later this year,finances permitting.
cros-over steering should improve the handling quite a bit.
rizzo
Port Huron, MI
Re: yah...
buy some disconnects so that you can hook the sway bar back up on the road.
mangus580
284
Western NY
RE: Re: yah...
I drove my 1009 for over a year, and didnt even know it was missing! until I put the lift in, and wondered hmmmmm what goes here? ;-)
Honestly, i didnt notice much when I put it in.
