M 1031 Farm Contact Service Truck
lavarok
33
Fellsmere, FL
I do agree. I would not run your house from it during an outage.
If you want to convert the generator to single phase, you can use the attached manual to figure out the wiring changes needed. This would be in the generator housing. See pages 9 & 10. I would choose diagram G which gives you single phase 120v and single phase 240v. I believe stock setup is diagram C.
However, doing this will require some rewiring in the panel itself and will affect the air compressor as it is three phase. So you will need to use a single phase motor for the air compressor which shouldn't be too hard to source.
I've often thought about making these changes to my M1031. If I didn't have two MEP003 trailer mounted gensets, I would have done it by now.
On a side note, have you ever had to replace the PTO (mag) sensor in any of your '31s?
b4thundr
LaFayette, NY
not as of yet the farm service truck came with a new one and the others are working ok so far, do you know of a source for them? the 220 water pump is really the only thing that is gonna be a heavy load.
lavarok
33
Fellsmere, FL
Muncie told me to use a distributor and sent me a list of them in FL.
Part number: 31T35108
If you ever need the mag pickup, you can email Muncie for distributors in your area.
I think I have a bad one, but am going to try swapping parts from another truck before I spend $80 on a new part.
Boreal21
Central Utah
My 1031 has been rewired to single phase, but the compressor motor wasn't swapped out when it was done. I've been wanting to tackle that project lately, but haven't had a chance to find a motor. Where do you think the best place to pick one up would be? Kaman? McMaster-Carr?
Any help would be appreciated :beer:
lavarok
33
Fellsmere, FL
Well, the tm lists the following specs for the air compressor motor:
Motor
Spec . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35S69-1342-MOO
Manufacturer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Baldor Electric Co.
Horsepower . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
RPM. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1735
Volts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 208 Vac
Frame . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 145T
Hertz . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 0
Phase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Amps . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.4
You should be able to use this data to source an appropriate replacement.
Boreal21
Central Utah
Thanks!
I'm still new to the MV thing, but I really need to learn my way around those TMs. I'll poke around for a replacement and post up what I find.
Sorry for the semi-hijack, Doug :D
mf5129
mocksville nc
i need the govenor for my 1031?any ideas to find one.i am thinking of using a throttle setup similar to a mep003 gen set.it would be manual
