M 1078 Road Trip
ciwhamc
California
Hi all. First post here. Going to be picking up a 95 m1078 in Missouri and driving it to CA. I am planning on taking 9 days and seeing a few sights on the way back. It does not have high speed gears so slow boat I will be. I am planning on taking some spare parts like fuel filters basic tools and other misc goodies. Is there anything I really have to have to make that trip?
I am planing on going I 70 all the way from Missouri to Utah. Up to salt lake and then 80 the rest of the way.
ciwhamc
California
I forgot to mention I am a mechanic by trade so fixing it should not be an issue. Just parts and tool availability would be the problem
NDT
7,436
Camp Wood/LC, TX
Don’t even leave until you have checked the driveshafts for spline wear. And if ok, check the tightness of the compressor, water pump and alternator bolts every fuel stop. Also check the fan hub for rubber deterioration.
ciwhamc
California
Thanks. That sounds pretty straight forward
ciwhamc
California
Is there an exact about of play that is a no go?
ciwhamc
California
Found it thanks . Think it’s worth bringing along front and rear spare shafts?
I will do a personal check of the truck before I take it. Luckily it only has 1400 miles on it
NDT
7,436
Camp Wood/LC, TX
Maybe. What happens to people over and over with these trucks is that driveshaft vibrations transmit up to the engine accessories and shake them loose, cracking the front timing cover and breaking the oil line behind the air compressor resulting in all oil loss in seconds.
WWinAK
9
Juneau, Alaska
Are there any specific tools that are not common that I need to bring?
Curious how your trip went, I bought a ‘97 And will be driving it from New Jersey to Arizona in January. Not ideal time of year for a road trip. Was hoping to gleen some more tips from another cross country vet.
ciwhamc
California
The trip went well. Broke at water pump belt in Denver but found part and fixed it all in all an easy trip. Longest day was 580 miles and the shortest was about 200.
