M 35 INJECTOR PUMP PROBLEM / Won't allow fuel to injectors
WOLF
Rochester Minnesota
I think I have a faulty shut off switch on my injector pump . When my truck wouldn't start I found my lift pump to be non functioning so I replaced it . Now I have fuel to the pump but nothing to the injectors . Does any one have an exploded view of this injector pump ?
Can I fix the shut off switch myself if that is the problem ? Can anyone tell me what the brand and model number are for the pump so I can search for the info. I need ? Thanks in advance for anything you can help me with . WOLF
3,115
RE: M 35 INJECTOR PUMP PROBLEM / Won
I think there are TMs in the tech section. There is a cover on the side of the F/P that the shut off goes to. Take the two screws out and use your finger to mover the lever inside that cover and see if it'll light.
DavidB
53
Southeast Wi.
If you are of mind to finger the shut off, have soldier number ready to stop air intake to kill engine.
DavidB
