M-543 vs H-1000
NDT
6,233
Camp Wood/LC, TX
If the teeth are fiber material, that is a safety feature that is intended to shear off if the pump locks. Looks like yours has been wearing over time. Might be time to get into a newer hoe (says the guy still running a 1988 Case 688 trackhoe).
poppop
39
Brooklet, Ga
Isn't that a rockwell clutch?? I think my old Link-belt had one like that. A lot of power units used them also. A clutch rebuilder should be able to fix it. When I bought the link-belt the clutch was bad and I had it repaired before I could move the machine.
rizzo
Port Huron, MI
I only use the hoe @ 6-12 times a year. should be good for what I need. I will check to see if it is a fiber gear. A fiber gear would fail with age right?
the gearbox is a rockwell. I'll know more when we get it off. I wonder if the gears wore over time or one of the pumps locked up. I am going to see if it will spin by hand.
M543A2
11
Warsaw, Indiana
I used to work at a company (Gatke Corp., Warsaw, IN) that made clutch frictions, or plates like that. I machined the faces of the friction material. The same kind is used in automatic presses and other industrial equipment. Frictions for oil well rigs of similar design were about 36" in diameter and 1" thick. It looks like an over-center engagement clutch. The friction material is a round, thick piece with a hole in the center and has the teeth molded on the periphery of it. It is trapped between the two steel discs to engage, driving through the teeth in the flywheel. I would say it just wore the teeth out to the point they finally failed. Someone may have had it apart and damaged the teeth putting it back together.
I do not know for sure, but I would think they are available.
Regards Marti
rizzo
Port Huron, MI
it looks like a fiber gear. I should have the clutch pulled off tomorrow and then I will know more. I cant see the other side of the clutch. I wonder if I can take it apart and put a new gear in.
rizzo
Port Huron, MI
here is a pic of the clutch a par. its a "twin disc"
here is the new disc. when comparing with the old disc I can see that half the teeth were wore off. Probably the reason they broke.
I am waiting for the bearings that go in the gear box, then I can put it all back together and into the hoe.
No.2Diesel
11
Huntington, NY
Hi,
Very cool...Another great use for the wrecker! Heavy equipment can't always be easily transported back to the shop making a wrecker a necessity!! Thanks for posting the pics...hopefully the parts weren't mega expensive. These old machines need a good rebuild every 40-50yrs... ;)
I have to tear down my little JD crawler loader final drive section to rebuild the steering clutches, undercarraige etc. and the parts add up quickly $$$... I was lucky that when my steering finally gave out, my crawler was in a good position and not in the way of anything....and it happened at home...
rizzo
Port Huron, MI
Hi,
I was lucky this broke in the same town I work in and not at my property that is 1/2 hour from my house away from town. Now I can stop and check things and work on it after work without having to make that special trip.
The clutch and gear box were apart before. bearings cost almost 500 just for the gearbox. I'll have about 700 into parts before I'm done. :( but with rebuilt gearbox and clutch, new belts and hoses. I will be good on that end for a long time.
NDT
6,233
Camp Wood/LC, TX
Congrats. Feel like fixing the worn bellville washers in the hyd pump in my 688 Case trackhoe that leave me without swing at the worst possible times?
