m-817 First start a no go.
PeteNora
Ishpeming, Michigan
I went to where my M-817 is stored. Truck is supposed to run. The temps are mid 40's this afternoon. Anyway brought 20 gallons of fuel. Loaded it with additives. Two new Interstate 12 volt batteries. Everything seems to be able to work. Primed to 80 psi., fuel heater on, 1/3 throttle and just cranks. Tried it about 8 times and the batteries were getting low. Never fired once. I have never owned this series Cummins and how they start. I was alone and a lot of snow on it and around it. The fuel primer likes to drip on the floor but still pumps up easily. Maybe its just to cold for it. I did not take any ether to tease it. Any ideas?
PeteNora
Ishpeming, Michigan
Was it last shut down with the emergency shut down cable instead of the switch?
That I can not answer. I did do a once over on all the controls and I did pull the emergency shut down. It did seem to function ok. I did do that last weekend when I went overe everything. When it did not fire I did pull and release it twice. It seemed to return ok.
Evil Dr. Porkchop
269
Colchester, VT
I'm fairly certain you need to open the hood and reset the shut off now.
Evil Dr. Porkchop
269
Colchester, VT
Ok I can do this. Is there a reason to reset this. I assume its just a push pull cable. What goes wrong? Just trying to learn the quirks on these trucks. And I do appreciate the help.
Nothing goes wrong but once it's tripped the cable does nothing until it's reset at the other end. Until then the truck won't start.
Evil Dr. Porkchop
269
Colchester, VT
PeteNora
Ishpeming, Michigan
I could come and take a look at it , I live in big bay and work in Negaunee
give me a call 360-1438
Thanks for the offer. I believe I learned on the emergency shut off. If that fails I will call you. Main issue is the snow and its in Spread Eagle Wi. So to go there it would have to be lunch on me and lots of beer.
