M-920 "Jake Brake"
GAR16
Perry, OK
I am hoping someone out there can help. I have a M920, the truck has less than 500 miles on it. I am having trouble with the engine retarder or "Jake Brake". Where or what do I need to check first? Thanks
reb87
Nebraska
As Floridianson said, the micro switch on the Injection pump(it purpose is to allow jake braking only when the throttle is closed). It can get loose and wont work properly unless the switch is positioned so the throttle linkage compresses the switch when your foot is off the throttle pedal. Also it will be intermittent if any of the electrical wires are loose.
GAR16
Perry, OK
The problem is there is no voltage anywhere. I'm wondering if there is a wiring diagram somewhere I can access it. Thanks for the replies. Steel Soldiers has always been a huge help in the past.
Castle Bravo
Hundredaire Socialite
231
Arizona
When mine wasn't working, I followed the troubleshooting information in the TM and it led me to what my problem was. My microswitch ("Sensitive switch") was out of adjustment and wasn't getting tripped correctly.
3,164
If it is an auto trans, there should be a switch in the converter lock up port. If that switch is failed, no power to any of the downstream parts. Start there by unplugging the switch and jumping it. The brakes will work without the truck driving. If it's a manual trans, check the clutch switch. Also, maybe start with the CB for that circuit.
