- 2,295
- 866
- 113
- Fargo ND
Hey guys here is the hitch I put on my 925, I had a priece of solid round stock that I machined to the same dimensions as the stock Pintle on the truck then welded the down tube to it with gussett inside, then the reciever on the bottom. In pic 2 that is the 24 volt to 12 volt converter box for the civy lights on my trailer, that is wired directly inot the harness of the truck. If you look under the point where the hitch inserts into the truck you will also see a bolt, its a 1/2 in grade 8 bolt that screws up into the hitch assembly to help control lateral movements of the hitch. When I want to put the original pintle on I unplug this hitch remove the big nut on the back and take this 1/2 inch bolt out, its then ready for the original pintle!
KK
![P6170083.JPG P6170083.JPG](https://www.steelsoldiers.com/data/attachments/299/299283-b7c333fb8c17aad270b4a7a2da385e5f.jpg)
![P6170084.JPG P6170084.JPG](https://www.steelsoldiers.com/data/attachments/299/299284-c13494d6bcae1e2ffdb54a7aaaf60d29.jpg)
![P6170085.JPG P6170085.JPG](https://www.steelsoldiers.com/data/attachments/299/299285-f28d4bbf6216477babe9c8017352a154.jpg)
KK
