I have a this deuce I originally bought for the winch to put on another truck. Anyhow it runs so well I’m thinking of keeping it for a while at least. About the only problem I have found with it is the lights do not work.
I disconnected the cannon plug from the switch and used a jumper wire from the hot connector on the plug to the lights , blackouts , etc and all seemed fine. Everything worked bypasssing the switch.
Well i I screwed a brand new switch to the cannon plug and nothing works. I suppose the prongs on the switch are not making contact in the cannon plug . Short of cutting the plug off and replacing any ideas on a fix? Maybe corrosion in the plug? If so how to clean? The jumper wire works fine though .
thanks
thanks
