M1008/1028 optimal tire sizes to offset 4.56 gearing
mangus580
282
Western NY
FMJ said:
I've done the 700R4 swap also. I did it to a 78 Chev K10, took out the TH350 and swapped in a 700R4 from BTOD, its behind a 400 hp 454 with 3:73's it's got about 20000 on it so far, no ptoblems. The 700R4 was just a bit longer than the 350 so the crossmember holes were redrilled, front DS lengthened, rear shortened. They include a lockup switch so you can tow in third gear without burning up the tranny. I'm very happy with it, so happy that the setup may end up in my 1008.......
When you swap out a 700 in place of a 400 (both on the 208 tcase), you dont have to drill anything. It is a TOTAL bolt in swap (provided you have the tcase and pedastal from the 700r4). Makes it really easy!
FMJ
37
Las Cruces, NM
Mine was a 203 T-case, so I had to get a custom output shaft on the 700, and so on.........
AJMBLAZER
Paducah, KY
I have 38" Michelins on my 1008 and it's totally different than the stock trucks I remember from my time in the Marines and when I first had it on 34-35" tall HMMWV tires.
I think anything that is ACTUALLY 36-38" tall would work pretty well. My 36x12.5-16.5 Goodyears were 34.5" tall in the back and 34" tall in the front with more than half tread left. 3" more tire and the truck drives sooo much better.
How wide you go with the tires does affect fitment though.
I would like to add an OD at some point though. 700R4 would be easiest but a NV4500 would be the greatest.
Croatan_Kid
New Bern, NC
I'm putting a 700R4 in my M1008 too. The only parts you need to change are the torque converter and the governor so it has that signature "diesel" shift/feel. I too have 11.00R16 Michelin XZLs to throw on it too, so it's getting lifted as well. They're on stock rims and they'll look awesome with 4 or 6 inches of lift. Eventually (soon I hope though) it's getting a turbo setup of some sort. I put the 11Rs on the back the other night and drove it and while it had more gitty up and felt faster at takeoff, I could tell it needed more power. Also, it felt like overdrive would still help, even with the tires measuring right at 38.5 inches tall.
AJM, what air pressure are you running? I've got mine at 40 front and 35 rear. 45 in the rear made it want to wander around.
Also, on the subject of an NV4500 swap:
http://www.4wheeloffroad.com/techar...n_5_speed_manual_transmission_swap/index.html
There's plenty of work an money involved, but I would love to drive one that had that done to it. I think it would be sweet! I aint got that kinda cash though! :(
AJMBLAZER
Paducah, KY
35 psi in the front and 30ish in the rear. Was night and day better from the 45 psi the tire place put in them.
Eh, I might be used to carb'd V8's and heavy trucks with 200-250hp V8s. Would I like to turbo mine? Sure. Do I feel it needs it now, no. OD gear and I'd be content with what I have completely.
