M1008 700R4 swap question
Dieselsmoke
CA/NV
Never thought I would do it, but now that I have multiple M1008s and a free 700R4 I'm gonna. So for those who have done the swap, what did you do for the gear indicator now that it has an OD spot?
Pretty sure I have everything I need ,TV cable & bracket, just wondering what to do on the gear indicator.
AJMBLAZER
Paducah, KY
Talk to Croatan Kid and mangus. They and a few others on here have done the swap. If you can find a whole truck with the 700R4 (preferably a diesel) then you have all the necessary parts right there. However be aware the 6.2L 700R4's are set up a bit differently than the SBC 700R4's.
Crash_AF
Colorado Springs, CO
Just find any proper bodystyle Chevy truck/Suburban/Blazer in the junkyard and pull the indicator from its cluster. It is only held on by two bolts and is a direct swap.
Later,
Joe
Dieselsmoke
CA/NV
The donor truck was a '91 1 ton, so the dash wasn't the same. Didn't realize until today that our body style was ever offered with OD, but was fortunate enough to find one in a buddies wrecking yard. So now I'm complete, ready to swap over...now I just need time.
AJMBLAZER
Paducah, KY
It was. Half tons and some 3/4 tons got the 700R4 in the 80's and in 1991 the crew cab 1 tons of our style got a 4L80E with a remote controller.
Croatan_Kid
New Bern, NC
I never bothered with mine.
The only aggravating thing is since it was originally a 3 spd, you can't pull it manually into 1st gear and hold it there.
Mtrdrms
Torrington, CT
Did a bit of searching on here but I was wondering, what exactly is needed to do this swap in a 1008? Will a 700 from a 4x4 gas truck bolt in? what about crossmember, linkage, driveshafts? I do not have a donor truck with a diesel but I do have one with a 350 sbc.
Andy
mangus580
282
Western NY
Hmmm I'm not sure why you couldnt find it, as I have listed it probably 3 times.
A gas one will work, but you will need to have a tranny shop make some 'adjustments' Ideally, you would have it rebuilt to be used behind the diesel.
Also, you will still need a bracket from a diesel for the TV cable.
Croatan_Kid
New Bern, NC
It's all a direct swap except you need a different spline on the transfer case input, usually just swapping the whole transfer case is easier and cheaper.
Anyway, a 4x4 TH400 and 700R4 are the same length and the crossmember and both driveshafts work just fine. All the linkages fit in the same places and even the transmission cooler lines will work, you just gotta give them a gentle bend by hand to get them to fit up into position.
If anybody needs a good 700R4 and matching transfer case for an M1008, I just pulled mine a few weeks ago and it's only got about 10,000 miles on it. Has a problem going into reverse when it's cold, but when it warms up it's fine.
