MadWooter
- 0
- 1
- Newark, DE
Hello everyone!
I've watched this site for some time, particularly recently as I've purchased a 1986 M1008 (and have just finally been able to get it tagged) and have been doing repairs on it.
Now I seem to have an alternator problem, and I'm left scratching my head and hoping that someone on here will be able to point me in the right direction. I've read a whole lot of threads on here about different alternator problems, but no one seems to have had exactly the same problem I've had, and a few links I've found seem to be dead. So, here goes.
When I got the truck, both batteries were completely dead because it had probably been sitting for a couple of years (there were even some sort of coccoons in the treads on the tires). Anyway, after I got new batteries and started driving it in the last week, I noticed that the belt on the driver's side alternator was loose (and making a whole lot of noise), and eventually tracked it down to two missing bolts on the power steering mounting which were letting it flap around. I've replaced the bolts, but now I seem to have a new problem. The other day I thought that the Gen 1 light was on, but it was very faint and almost invisible in the daylight. The voltmeter was pointing right between the yellow and green areas. However, at some point the light went out, the voltmeter went back into the green, and I was able to drive the truck offroad for several hours. Last night, however, this happened again, but the light did not go out and now it comes on whenever I start the truck. It glows very faintly (much less than the Gen 2 light) before cranking the engine. Using a voltmeter, I see that the front battery has less voltage than the rear, and that the driver's side alternator does not seem to produce power.
Looking at other threads on here, I've already tried cleaning corrosion from around the Gen 1 lightbulb, but there was none. The alternator is spinning freely and not making noise, but produces no power. Given the writing on the alternator, it seems to have been replaced in '03, but like I said I don't think the truck has moved for a few years. There does not appear to be any corrosion on any of the alternator terminals.
Is there anything else I should check (a relay for the charging circuit, maybe?) or is it safe to assume the alternator is fried somehow and needs to be rebuilt? I find it strange that it seemed to fail the other day but just came back to life on its own. Also this problem only seemed to start after I replaced the bolts holding the PS pump in place. I don't know too much about this truck, and my only other real experience with working on a vehicle is my '88 Celebrity. Any help would be greatly appreciated on this.
Oh yeah, and does anyone have any idea why turning on my windshield wipers in any way also turns on the wash mechanism? Bad switch maybe?
Thanks a bunch in advance, and sorry about this huge post.
