M1008 Axle question
ccf460
granite falls/N.C.
I am looking at buying a herd of cucv's, and have a question: What front axle options would be found under the "truck" based cucvs? I am familiar with the dana 60 , but have been told there could be other less desirable front axle assemblies. If it helps, 2 are the standard M1008 type trucks, and 2 are what looks to be ambulance type trucks with walk thru cutouts from the box to the cab. Thanks.
Gripy
Los Angeles, CA
The m1009 (blazer) has a Dana 44 in the front and a 10 bolt gov lock in the rear. 3.08 gear ratio
m1008 (k30) have D60 in front and 14bolt detroit locker in the rear. 4.56 gear ratio. The thing is for the trucks m1008 and other variants is that some have a limited slip diff ( m1028 ) in the front axle (you don't really know unless you pop the cover off and look)
cucvrus
10,131
Jonestown Pennsylvania
I was always told that the M1009 was NOT a Dana 44 front axle. If it was I could sell everyone I have to local off road clubs. It is a GM 10 bolt axle also. I am open for clarification on this issue. Anyone? I don't see a 44 on the differential cast iron center flange gusset. Am I right or wrong? Please advise.
Westech
CPL
6,104
207
cow farts, Wisconsin
GM did NOT use a 44 in the blazers. It is and only is (proper English) a corporate ten bolt 8.5 inch axle. Having said that the spindles and axles can be interchanged but NOT the carrier.
ccf460
granite falls/N.C.
Very informative , Thanks. I just sealed the deal on these this morning before church. Looks like I am the proud owner of 2 M1009s, 2 M1010s, 1 M1008, 1 M35A2, 1 M101, 1 M416, 1.5 ton genset trailer, 2 S250s (i think that is what they are), spare deuce parts, spare M880 parts, etc, etc, etc.....
scottladdy
CT
Jealous!
But seriously, good luck with them!
ccf460
granite falls/N.C.
Belftfed,
Granite Falls is about 3.5 hours west of you. I am planning on moving most of the stuff, though.
ETA: I bought this collection with an eye on mainly the deuce, m101, shelters, building 1 good cucv. The rest I am hoping to find homes for.
