goldneagle
- 989
- 113
- Slidell, LA
I bought a M1008 truck from GSA. It was a former fire company truck. Had signs of blown battery on passenger side. Juanprado helped me with the passenger side alternator. After messing around with it for a while he noticed someone had reversed the 2 large red cables on the alternator. (that probably explains why the battery blew up) The alternator was toast. Fuseable link was damaged at the 24volt bus bar. I repaired the wiring and installed a new isolated ground alternator on the passenger side. I also replaced the alternator on the driver side since it was not charging the battery either.
Now the alternator on the driver side charges the front battery. The passenger side alternator was not charging. After testing I determined that there was no negative current going through the red with white stripe wire. I used the wiring diagram to locate the other end of the wire. At the 12 volt terminal the fuseable link had melted inside the blue insulation. I replaced the fuseable link and tried again. Still not charging the back battery. I tested the red and white strip wire and got ground. So I know the two main cables are hooked up and passing current as they should.
Now I am thinking maybe its the red and black wires that go into the plastic connector. I know the red 1 goes tot the 24volt bus bar. Not sure where the other wire goes. What is the function of those 2 thin wires and where does the 2nd one go?
