- 2,144
- 101
- 63
- Maine USA
Trying to help out the local forestry get their M1008 back up for fire season. Driver said when he went to start it during the glow plug cycle he heard a snap or pop bang etc and everything went dead. I went over and checked the battery voltage 26+ volts, same at the glowplug relay, have 13+ at the firewall block. Nothing will turn on, I mean nothing, no lights no ignition nothing, as if the batteries were missing from the truck. I jumped the starter connection at the starter relay and it spins over fast and strong so I know the batteries are good and the starter system is ok. If you have the meter on the light fuse and are reading 13v and then turn on the lights the meter goes to 0. This usually means a bad ground but it's affecting the entire electrical system. Wondering if a bad or shorted alternator could cause this. All the grounds are solid. Hoping someone has had this happen before. I have been driving these things for 20+ years and never have seen this happen before.
Thanks
Thanks
