M1008 - first drive
warwick
Maryland, USA
The front battery was dead and the back was low...charged them and they held a good charge
while the bats were charging i had a chance to look over my GL M1008, everything is where it should be and in good shape. I put the bats back in fri afternoon, two tries nothin....
third try rrrrVAROOOOM... rattle,rattle,rattle,rattle..... :mrgreen:
I live out in the country so i went for a shake down run on some back roads....runs good no problems except for the GL bent rear drive shaft
as soon as I get my SF-97 and have my drive shaft retubed it should be good to go
thanks to SS , between the cucv manuals and a quick search I was able to answer most of my questions
Brian
Croatan_Kid
New Bern, NC
I seriously got lucky! I put in a new rear battery, fired mine up, drove it on the trailer, and the rear driveshaft was straight! :D
Cool beans on the new truck! No matter how many time you drive it, it'll still make you grin!
BobM
Fillmore, Indiana
Mine sure did! Even tho I had to retube the driveshaft and need to replace the tranny to TC adapter. The second looks as you drive are a real hoot! And I can already bet that directions around here will be given using "you know the guy with the Army truck" in them! :wink:
