Drock
- 12
- 0
- Eatonton GA
I'd like to plumb it like factory. Isn't that just a solenoid valve & the switch on the dash? Or is it a different fuel gauge & lines thing?Same goes. No. And the tank is the same tank just switched around. Same brackets also. The plumbing is fairly easy. I had one and Y ed the suction side. It pulled almost equal and I only used the stock left sending unit. It was NOT dead on but accurate enough. I have a few that the fuel gauge is accurate and others not so good. the only way I ever fixed the issue was changed the head unit gauge and the sending unit with new. A few it was just one or the other. But both were fairly inexpensive and it solved the issue rather inexpensively at the time. Good Luck. You could even fill the right tank thru the rear wheel opening so no hacking thru the bedside and trying to fill it in again.
