The air leveling would work great in the rear. I haven't had much time to work on a front system. I got off track adding a third battery and power inverter under the hood. Very time consuming. I might replicate the back front spring holders and make them adjustable in 1/4" increments. They would be hard to adjust, but how often would you need too. I'll get into it, if I can't make it stronger than it is now then I will leave it alone. I already bought new springs so the front end should be good for a few years. I would like to install another fuel tank or accessory on the passenger side to offset the weight.
