M1008 M1028 Differences
Westech
CPL
6,104
207
cow farts, Wisconsin
Vin> well the vin is going to be different for every truck..... the 1028 had a locker in the front I think and a overload spring in the rear.. also the t case might be different from what I remember. For the most part there the same truck.. same trans, same engine, same axles.
m4A1
California
The tell tale is the vin as stated above and the overload spring in the rear of the M1028. What you dont see is the limited slip in the front for the M1028.
kenny
San Antonio Texas
The m1010 has hd in the vin And I do not see overload springs.
Is it just a extra spring in the spring pack in the rear?
ken
25
Houston Texas
My 1028 has the NP205 iron transfercase. Where the 1008 a had came with the NP208. My 1028 also has the limited slip diff up front. But the 1008 had a open front diff. They both have the overload rear spring. The 1028 has some wiring that goes to the bed. I assume to power the shelter. I removed it however.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Don't forget the A2s and A3s. (Which the only difference is the transfer cases).
acmunro
Reynoldsville,PA
You should have a M1028A1 then not a M1028 as a M1028 would have a NP208.
