m1008 no start
k20
Monroe, NC
Aha, I figured it out, when I got the truck, I hooked the battery cables up how they were made in the truck. The battery cables looked new, but it wouldnt turn over, so I replaced em. Well, bad move, because the cables were in the truck wrong, the feed to the cab was off the positive side of the 2nd battery. Basically the cab was getting 24v so yeh, hopefully nothing else is fried.
Im actually hoping the burned up FSS was the reason the Marines parked it.
mangus580
284
Western NY
Glad you found the problem!! You might be replacing lights for a while ;-) I think thats about the only thing that would have really suffered.
jimsjtaac
a bicron 26214 12v is the same solenoid used in a john deere fuel injector pump. mine is a jd 300b-industrial backhoe tractor. the fuel injector pump is used on many different machines- cotton pickers, crawlers, tractors etc. anyway my solenoid is in the injector pump and it turns the fuel off-apply power to the solenoid and it closes and lets a spring loaded valve in the pump open. turn off the key and the solenoid opens and closes the valve, shutting off the fuel. STANDYNE is the distributator--just yahoo standyne and you can get 100's of dealers over the us and world--most are diesel injector & pump services. dealer in austin, tx. charges $109.00 for this solenoid.
