M1008 pintle hitch
1,193
I am wondering, how much load you guys are putting on your stock M1008 or M1028 pintle hitches. I am about to go to Haspin (750 miles one way) and I need to determine which trailer to take and what I can put on it. I am also running with my truck camper(1100lbs) on the M1008A1. I did just install an electric brake controller for my civilian trailer(2800lbs empty).
NDT
7,440
Camp Wood/LC, TX
I once towed my D-3 Cat dozer on a 3 axle pintle trailer behind my CUCV. It didn't break off. (21,000 towed weight, 1000 tongue weight) Took it reallly slow . . .
papercu
33
Baxley, Ga.
Tow wise, they pull airplanes with them. Wayne
M1009. Equipped to tow M416 Series 1/4 ton trailers with maximum towed load
of 1200 pounds for both cross-country and highway travel. Load on tongue should
not exceed 100 pounds.
FA1008, M1008A1, M1028, M1028A1, M1028A2, and M1028A3, Equipped to tow
M101 Series 3/4 ton trailers with maximum towed load of 3100 Ibs. Load on tongue
should not exceed 300 Ibs.
Guidelines for Towing Aircraft Which Exceed Maximum Towed Load Weight
(3) Gross load will not exceed 10,000 pounds for M1009, 15,000 pounds for M1008,
M1008A1, M1028, M1028A1, M1028A2, and M1028A3.
(4) Tongue load will not exceed 100 pounds for M 1009, and 300 pounds for M1008,
rizzo
Port Huron, MI
I used a M1009 pintle to tow my M543A2 with it about 15 miles. I used a tow bar so there was very little tongue weight. It did not break
bp m1009
Somerset County NJ/ NE PA
is there any way to get something that bolts up to the factory hitch on a m1009 to convert it to a regular ball hitch? mine has that hitch that clamps like a mouth (i dont know wat its called im new to the cucv world)i want a regular ball hitch but i dont wanna buy a trailer hitch
1,827
If you shop dilligently on Ebay you can find that combo hitch at a buy it now price of $26.
Here, I did the search for ya.
http://cgi.ebay.com/Pintle-Hitch-with-2-5-16-Ball-Valley-Ind-69980_W0QQitemZ110364815005QQcmdZViewItemQQptZMotors_RV_Trailer_Camper_Parts_Accessories?hash=item19b2416e9d&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1240%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Guess they are out of the ones with 2" ball. Keep checking, they might relist. I've bought 3 so far.
bp m1009
Thanks guys thats exactly what im looking for im gonna pick one up im making my m1009 my new landscaping truck so ill be towin an open trailer with a mower and some gear should be great, probly will be the most badass landscaping truck haha
motormayhem
Tucson, AZ
Sounds like fun!! Just remember those 308 gears aren't very good at heavy loads. Might want to install a tranny temp guage and a pyro.
adrianspeeder
599
Harrisburg PA / Dover AFB DE
Got mine for a little more at tractor supply, but wanted to tow right away.
If I had to do it again, I'd try a little harder to back the big stock pintle swivel nut off while the mount plate was still on the truck. To take that out means a complete unbolt of darn near everything on that rear bumper.
Adrianspeeder
REGULATOR
Martinez GA
oh how I love the search feature...
got to run to Harbor freight anyway, need a grease gun, some sand paper and now a pintle hook combo...
sure I'll walk away with soem other crap I didn't need but hey.
might grab a louder horn too..
mattsmoski
spokane , wa
Pintle hook pattern bolt-on receiver tube 2" I.D. # 1804055 "Trailer Parts Superstore" 49.95 shipping 16.00
This might work for you, will bolt on to where that mouth thing is.
