M1008 resistor
87cr250r
2,137
Rodeo, Ca
Just as a wild guess.. Check the ground wire that connects from the engine to the fire wall.
Take both sides off and clean the connections.
This one is important. I forgot to connect it after R/R'ing a head and the engine used the steel lines between brake master cylinder and proportioning valve as the ground. They started smoking while glow plugging.
