Durango_USMC
- 0
- 18
- Indianapolis, IN
![2013-02-17_18-13-09_529.jpg 2013-02-17_18-13-09_529.jpg](https://www.steelsoldiers.com/data/attachments/283/283039-79055cd0d8400cf7eb657b3c6402fb78.jpg)
![2013-01-12_16-23-04_856.jpg 2013-01-12_16-23-04_856.jpg](https://www.steelsoldiers.com/data/attachments/283/283038-f208c97c127fec13a514c0dee5f27176.jpg)
The Good:
Body is pretty much straight and only has a rusted cab corner, I will need wheel wells, a passenger side fender, and to beat out the dent in the door.
It starts and runs pretty strong.
4 wheel drive works, as do the locking lugs. I was incorrect in saying this. 4x4 is unknown at this time
I really like this truck.
The Bad:
I think my garage is the first time its had a roof over it for more than a day or two...
Voltmeter is inoperable
Coolant Leak - Found out it was about 3 cracks in the coolant overflow tank. I replaced the tank no more coolant leak.
Gen 2 light does not turn on
Electrical gremlins
2 Oil leaks - At least 2....
1 transmission leak
Power steering leak - Turned out to be steering stabilizer. Replaced with Tuff Country stabilizer from Off Road Design
My Goals:
I'm going to start with attempting to sort out if I need a new voltmeter or not.
Sort out the coolant leak if there is one (fluid is very low, and could use a flush). - Done
Oil change.
Replace black out drive light and read black out light.
Then move onto the Gen 2 issue and the electrical gremlins in the headlights
Address the two oil leaks... Not sure if I will do this myself or farm the work out. I'd like to do it but I dont have a lot of space, time, or equipment.
Its been suggested that I go ahead and just redo all the gaskets in the engine so hopefully I dont fix one thing just for another to fail
Body work and paint. I'll probably keep the same 3 color woodland paint scheme but it could use some freshening up after I replace the cab corner, fender, fix the door, patch sosme rust holes in the tailgate (or a new tailgate, havent decided.
New lock cylinders and ignition.
A few more gauges (tachometer, engine temp, pyro, trans temp), a CB, and soem additional lights.
As well as whatever else seems to pop up.
I'll be asking a lot of questions, yes I know some answers are in the TMs and some are not and some of you have devised better ways to get things done with a little less headache than the TM's let on. Please feel free to chime in with anything helpful. Forgive my spelling, I will do my best but sometimes my phone is a real pain in the rear to type with correctly. While I encourage discussion, please dont drag my thread off into some wild tangent to get it locked or so that anyone else reading has to flip through two pages of bickering over 12v vs 24v. Thank you for your time and consideration. I look forward to learning a lot and sharing my experiences with everyone here.
I'm going to attempt to upload some pictures shortly... I'm having a few minor technical difficulties.
