M1008 spindle remove/replace
firefox
General
1,844
51
Berkeley CA
Please check my procedure.
1-remove wheel
2-remove locker assembly
3-remove caliper and secure with wire
4-remove 2 axle nuts and tab washer
5-remove 6nuts and lock washers from nuckle
6-remove spindle and associated bearings, rotor,
parts as a complete assembly
7-pull out axle shaft assembly
Can I do this, or am I missing something?
I would like to be able to do this so I can change out the kingpin,bushings, and bearings now,
and change out the wheel bearings and seals at another time. I have to do this on the street in front of my house, so I can't have my truck non operational for more than 12 hours at a time. I am partially disabled so I am not as fast as the rest of you are.
Thanks,
Bruce
doghead
4 Star General /Moderator
1,188
NY
From the -20 TM(right click and open in new window, for bigger view.
DieselBob
15
Arnold Maryland
Slight change to the list
1-remove wheel
4-remove 2 axle nuts and tab washer and associated bearings, rotor,
6-remove spindle
bronconut
wisconsin
if you dont have a spindle puller and slide hammer i would suggest you try to rent one or you may have some difficulty removing the spiddle, if one is not availible a block of wood and a hammer will work but hard and time consuming. good luck
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
Actually, the spindle hangs over the knuckle in one spot, which offers plenty of room to tap with a hammer. Once you get it to move a little, you can work it back and forth to get it off. It shouldn't take more than 2 or 3 minutes.
skateabrock
anchorage, alaska
life will be much easier with a hub nut socket, trust me! Also, I have never EVER seen a bad kingpin, they are a pain to replace, so make sure its bad before you remove it, i know that they are torqued down extremely tight.
