Finnegan1008
- 164
- 43
- Connecticut
I will soon be changing the water pump on my m1008. I figure when I have front of the motor apart I should do the timing chain. Would you all recommend this?
If so what TM outlines the procedure? I can’t seem to find it through my own research or searching the forum.
Is there anything else I should check or replace while I’m in there?
