M1008 VS M1028 for Fuel Ecconomy?
hotbox
Charlotte, NC
That's right. I never carry alot of weight. I use it as a shop truck, everyday. Don't need to worry about smoking the turbo 400 tranny. I have other large trucks for heavy loads. The axle swap is cheap if you already have them. The object is to have a daily driver on WVO. No fuel expense!
rickf
2,213
Pemberton, N.J.
Until winter when it will not run because the fuel turns solid. I am surprised it is running straight WVO. 6.2's do not generally like to run on anything but clean diesel.
Rick
hotbox
Charlotte, NC
Winter here is mild. I have run straight WVO at 40 degrees no problem. I also added a filter/ heater to reduce the viscosity. When it gets cold i cut the wvo 70/30. All four of my diesels run well on WVO. Diesel is an engine design, first. The first engine Mr. Diesel designed ran on Veggie Oil, because "diesel fuel" was not invented yet.
rickf
2,213
Pemberton, N.J.
I would love to even have access to it. There are reports of people stealing it from restaurant holding tanks. You have to have all kinds of permits to handle, move and store it here in NJ now. I was going to get them but now that people are charging for the waste oil I said the heck with it. The price of everything involved came to way more than straight diesel fuel. So much for going green, all involved want to line their pockets with green to let you go green.
Rick
wallew
Let me help you boys out
that's MY M1028A2 towing MY M1009 from Ft Riley, KS to Denver, CO with a medium tow bar
I've also towed the M1009 from Denver to San Angelo, Texas
And ALL AROUND the DFW area
ZERO PROBLEMS, ever
mpg is 10 mpg because I'm towing 5700 lbs of weight
I DO NOT SPEED. I'M VERY CAREFUL. And I ALWAYS give right of way to ANY BODY ELSE. Both vehicles are box stock and have been carefully maintained.
hope that helps
hotbox
Charlotte, NC
We have a little of the stealing WVO here too. I get it from 3 Restaurants. They get paid for it here and turn it to chicken feed or something. You just have to beat the bushes. It was illegal here but someone sued the state and won! You can make it and use it but not sell it. Because of the road tax thing. The government says they want to go green, until it takes taxes out of their kitty. I have huge tanks on all my trucks and haven't bought fuel in years!
Keith_J
1,328
Schertz TX
Rebuilt injection pumps are $400. Injector set is about the same. Even at $4 a gallon, that will buy you 3000 miles of diesel in a CUCV.
I'd rather use the right fuel than have to replace the fuel system.
We towed my M1031 from WI to TX at an average of 13.2 MPG. And with full AC in the tow vehicle at 60-65 MPH.
islandguydon
787
Michigan
ZERO PROBLEMS, ever
hope that helps
I agree with wallew, especially on the "ALWAYS give right of way to ANY BODY ELSE" ..Tip.
BTW, I aspire to one day own a dually as nice as yours. Good looking truck man..![thumbzup][thumbzup]
hotbox
Charlotte, NC
I have been running WVO for 5 years. The only problem is when you first switch over you need to change the fuel filter a few times. The WVO cleans the carbon and build up from the tank, injectors and combustion chamber. WVO is the right fuel for all my trucks. I save $25,000 a year by using Clean WVO! Oh, and it contains about the same amount of energy per gallon with far less emissions. I only use a 70/30 mix when it gets very cold. You keep paying and I will keep driving past gas stations.
