M1008 wheels
WWRD99
1,925
York Pa
My M1008 has 16.5 wheels, can 16s be used. 16.5 are hard to find in UK
Mine has 16s on it... they're 6.5 wide...I put a 265/75 16 on them and they fit great...from what I've found there's a ford rim out there that is the same lug pattern but a bit wider, I think they're 7 inch...I do think that the one ton gm trucks in 16 inch will fit as well...this tire size was a little taller than what was on it, the stock size and over an inch wider and they fit great.
Sent from my SM-G955U using Tapatalk
LT67
515
Bowdon, GA
The ford 16x7 will bolt right up.... and a 255 85 16 will fit just fine with no fender rubbing
WWRD99
1,925
York Pa
Yes that's what I wanted but I didn't think a 6.5 inch rim would work well with that...I literally just picked up a brand new Ford set last night...wish I would have known the originals were bent up before I bought new tires!
LT67
515
Bowdon, GA
KM2 255 85 16 on my 86 M1008 on the factory 6.5 wide wheels
