pa.rich
- 9
- 0
Oh yes, forgot to say I have a 87 K30. 1 ton dually dump.
Thanks for the info MB4wd. I've looked at some of the treads on here about the Gear Vendors, and went to their site. It sounds like a great option. In overdrive it changes your axle ratio from 4.56 to 3.56. The problem with it is, the $2995 price.. I'm on a tight budget, I still want to do a 6.5 turbo install, and a new paint job by spring.
just finished mine, trans was free, spent 300 on torque converter, 60 on flex plate, 100 on tq lockup kit, 25 on bracket and tv rod, 16 on tv cable and 200 on transfer case w/adapter total=686. I'm getting 20-21 with an average speed of 55-60, at 55 i'm at 1900 rpm's, 70 is 2500 rpm's.
235/85/16what size tires (??")
im liking the specs given..
700r4 , 203/205 TC.. ( keyed in manual specs for high, low, and double low) 4.56 gears , on 37"
Shows i will be at 2028 RPM at 70MPH...
I'm so going to start sourcing parts now to do swap this fall...
