m1008 won't start after 2 days of 30 ish at night
CUCVLOVER
Hi Everyone this is my first post so please excuse any errors.
OK so once it turned cold myvtruck wouldn't start if it sat for two days but if I started every day it was fine. It was like the batteries were dead. They are only a year old and they both are interstate crankers with about 1200 cranking amps and 850 cold.
Any advice would be greatly appreciated
Thank you
1,174
Start by charging and load testing your batteries.
Next, check you battery voltages off and with the truck running.
Tell us what you get.
CUCVLOVER
Thanks for the info. I have checked the voyage at full charge and on both batteries its about 26 volts and running with nothing on and alternators putting out I get 29 ish but I don't have a digital tester just an analog.
The batteries hold plenty of charge when its 40 F and up and
I have never have this problem when the truck has warmed up.
Also when I crank it up I get the impression that if the motor was locked up the batteries would knock the starter off on the ground. I have 6 kc lights on top of the truck for 600 watts of power and I have another 200 watt in the brush guard and I have the biggest head lights that is made for the truck and it runs all that fine.
Thank you
1,174
Drive to a store and get your batteries load tested.
MarcusOReallyus
814
Virginia
Thank you
Hi, and welcome. Once you get the starting problem worked out, you probably should look into a headlight harness upgrade. That headlight circuit is a marginal design, and it's 30 years old. It really can't handle much extra load.
:beer:
1,174
My next thoughts are either the starter motor is dieing or an alternator(diode trio) is draining a battery.
1,174
When you measure the battery voltage, simple check each battery individually at it's terminals.
Report back like this,
front bat, off voltage xx.xx
Front bat, running voltage xx.xx
Rear bat, off voltage xx.xx
Rear bat, running voltage xx.xx
Looking for 12-15 volts roughly.
No 24 volt readings this way.
CUCVLOVER
:beer:
They have died before, now the truck has new head light, blinker, and dimmer switches. And bypassed blackout switches I wanted to keep them working But I needed other stuff more
CUCVLOVER
Iv done that and it is in the range you described and I've checked in different temps just not when it wouldn't start I just charged a little and it cranked
phil2968
Lakeland, Florida
Check the battery voltage after charging and sitting all night. It should be 12.5 volts. The difference between fully charged and dead is only .5 volt. That means 12.2 volts in a rested battery means it is really low. 12.5 does not mean it will pass a load test however.
CUCVLOVER
phil2968
Lakeland, Florida
Trying to work on electrics without a VOM is like trying to test blood pressure by feeling your arm. Just ain't goin' to work out!
I have been able to feel the "tricity" is wires a few times though. Usually spark plug wires!
MarcusOReallyus
814
Virginia
The problem isn't the switch, it's the supply circuit. Fried fuse boxes are not all that uncommmon.
But I don't want to sidetrack this thread, so I'll just give you a few links to check out and shut up on this. :)
CUCV Headlight Circuit
http://www.steelsoldiers.com/showthr...dlight-Circuit
CUCV Melting Headlight Fuse and Horn Circuit fix
http://www.steelsoldiers.com/showthr...t-fuse-melting
LMC Headlight Wiring Harness upgrade
http://www.steelsoldiers.com/showthr...ht-circuit-mod
