m1008 won't start after 2 days of 30 ish at night
cucvrus
10,505
Jonestown Pennsylvania
Not in 30 degree weather. You have other issues that need addressed. Start from scratch and check out the entire glow plug, starting system. It sounds like it has issues.
1,191
First off, glow plugs will not make is crank slow.
We have covered the GP system 1000's of times. You are best to read and follow the troubleshooting section in the -20TM to correctly troubleshoot that system.
You need to start with load testing your batteries.
With one or both batteries not up to par, the GP system will not work correctly either.
MarcusOReallyus
819
Virginia
You may have a GP problem, but one thing at a time. As doghead say, GPs won't make you crank slowly.
What kind of oil are you running?
Westech
CPL
6,104
211
cow farts, Wisconsin
Do you really think that 15w-40 engine oil is too thick at 30*?
Come on and use some common sense!
If it is not starting at 30* you have a major problem.
cranking fast but no start? Glow plugs.
Cranking slow and no start?
Batteries/starter.
its just that EZ
1,191
Ok. Would a block heater do any good?
Not for bad batteries.
Simply drive to an auto parts store and have them load tested.
Or, take them out and get them tested.
cucvrus
10,505
I think its time to drain the oil and filters each night and take it in the house with you to keep it warm. That is what the Germans had to do during the1942 Russian campaign of WII. That should work. Warm oil will start it on the first crank.
1,191
Because batteries fail in the cold.
Every year millions of batteres go bad when the cold weather hits.
Is this the first vehicle you've ever owned?
rsh4364
15
greensprings ,ohio
Wow I just had a flashback to when I was 19 and married with a new son,I had a 67 Mustang I used to drain water out of every night to keep it from freezing every night then add warm water in morning.Between bills and eating just couldn't afford anti-freeze.Wow I feel old now
CUCVLOVER
Yes this is my first road rig. And I recently bought a 74 cj 5 that I've been working actually I ordered a new starter and several new parts for it today. Since about the age 8 I've been working on and maintaining a 70' ish coot that I helped rebuild in 05 I upgraded the engine a few years ago and I rebuilt the entire running gear about a year and a half ago. And I've worked on boats, bobcats, bull dozers and some of my dads vehicals. So I'm no stranger to working on all sorts of things
