M1008A1 front driveshaft dust boot
Tinstar
2,613
East of Edmond, Oklahoma
Where can I find one??!!
Anyone know the front shaft OD
or a replacement boot #?
The TM shows part #7845127
Did a web search with part number in the TM
No luck
Searched SS site
No luck
Called Spicer
nothing crosses to spicer number
and they have about 20 different dust boots
Gave them the complete shaft number
No luck
Only solution is to cut it off and measure ID of
boot and hope Spicer makes one that will fit.
Thanks!
doghead
4 Star General /Moderator
1,193
NY
I saw limited quantities listed, did you try contacting any of them?
Fleetpride is where I go for all my driveshaft repairs.
Tinstar
2,613
Yes
all out
my driveshaft place needs the ID of boot
or OD of shaft
don't want to cut it off right now because of dirt and mud
Cant fine the specs of the shaft itself
Part numbers yes
Specs no
cucvrus
10,505
Jonestown Pennsylvania
Take it to them. I have the front driveshafts rebuilt for about $120. when i drop them off bent. Any truck that vibrates with the hubs locked i send the driveshaft out for rebuilding. Not an everyday event but when it is bent or the spines worn out you do what you have to do. I took the dust boot off of a few and just clean and grease the splines on a semi annual basis. I found the dust boot was a rust and moisture holder when ever it had a small tear in it. It would collect moisture and just cause more problems. that me do as you must.
