M1009 85 cucv fuel filter conversion to new scerwon filter.
kclark
Maylene/Al.
My fuel filter on my 85 M1009 CUCV 6.2L diesel is pouring fuel. I want to convert it to the screw on filter. What style/brand do yall recommend?
doghead
4 Star General /Moderator
1,176
NY
If your sensor is leaking, a simple oring may fix that.
Others have jbwelded it and yet others have screwed a screw in the hole.
Where is it leaking from?
kclark
Maylene/Al.
I have not dug into it yet to see where the exact leak is coming from. it is leaking from the back of the filter mount plate. everyone just recommended replacing it as oppose to fixin it...
doghead
1,176
NY
OK, but personally I would look at it first, you may only need to tighten a thumb screw.
Search for threads on filters, there are tons of them. Everyone does it with whatever they find available.
You may find more in the CUCV modifications forum(if people could post in the right place ever)
Drock
12
Eatonton GA
Agree with Doghead , the stock filter base can be fixed / rebuilt for less then ah dollar worth of O-rings from Ace hardware and ah piece of vacuum line. Although the 30 year old plastic sensors tend to be brittle, therefore the stock base is known to be problematic. The other choices are a NAPA filter base #4309 and some fittings, fuel line and the filter for around $50.00. Or the expensive route is the Stanadyne FM100 filter + base. Which can be optioned out with a fuel heater, clear sight glass drain , electric fuel pump, and other gadgets. Mine with the fuel heater and sight glass was around $160.00.
