M1009 Alternators
bcolemanttu
Dallas/TX
Is there any reason this alternator won't work on both sides. Does anyone know anything about this company?
I looked up ODIRON and i guess they are out of business.
I want a full set of spares so i will get my current ones rebuilt.
Thanks in advance for the help
OEM(s): Delco
Voltage: 12 Volts
Amps: 100 Amps
Rotation: CW
Regulator: IR
New or Remanufactured: New
Approximate Weight: 17.12 lbs / 7.78 kg
Short Description: DELCO 27SI ALTERNATOR
ADDL INFO: TYPE 100
ADDL INFO: INSULATED GROUND
ADDL INFO: MILITARY APPLICATIONS
Part Numbers
AC DELCO
321-744
DELCO
10459234, 1105500
Applications
This Is A Isolated Ground 1105500 Gm Alternator For M1008, M1009, M1028, Cucv Military Or Civilian Use Trucks, These Applications Use 2 Of These Units On The Engine.
1,168
Did you know that our site rules prohibit posting ebay auction links?
That alt looks good but I would confirm with a meter before installing.
Skinny
486
Portsmouth, NH
Is yours missing?
For that kind of money, I would buy a rebuild kit and do it yourself. Could probably have it done for about $30-40 in parts.
Warthog
227
OKC, OK
ODIron has been out of business for years. More than likely he will never be back in business.
You need to edit your post to remove the link. No eBay or Craigslist ads are allowed. Even "buy it now". Those are the rules that the site owner has issued.
cucvrus
9,688
Jonestown Pennsylvania
How much are the new ones. I have a local guy that makes me new ones from 100 amp GM alternators. He puts an isolated ground in them and they work fine. I am on the phone with him right now. He wants $150. each for them. Let me know if you want any.
1,168
Actually, I think there is a possibility that John will try to make it back eventually.
360
southern ca
Not sure why the same alt wouldn't work for both sides. I ordered a couple from rare electric. They worked fine for about a year and a half and one crapped out on me. The thing started whining and smoking so off it came. I keep a spare on had so that saved me. But my local diesel shop located me a suitable replacement which I have on it now. Always good to have a spare. In fact I may order one more just to be done with it and a rebuild kit. I'd like to salvage the rare electric that died on me. Never rebuilt an alt but got nothing to loose.
Skinny
486
Portsmouth, NH
You should be able to get any 27si rebuilt as an isolated ground using the correct rebuild kit. They are really nothing special, just need to make sure you order the correct parts which are available pretty much anywhere you can buy Delco rebuilt kits. The only issue is the quality...good luck. Sometimes you don't find out till you spend the money.
As far as a spare, every CUCV has a spare alternator. It is mounted on the right side of the engine. Realistically you only need one alternator feeding the 12v side. If one fails, just put the good one in the Gen 1 position. Gen 2 is really only needed to charge the starting battery or if you are running true 24v loads. I wouldn't sweat it. That truck will start many times before Batt 2 gets low. Worst case, you can always charge Batt1 while driving, then swap it for Batt2 if an alternator died. Probably a better move to buy the rebuild parts and keep them on a shelf than to rebuilt one and toss it in the truck.
