M1009 antenna bracket mounting points, hardware
maddawg308
825
Appomattox, VA
So I have completed my move to the new location, and getting set up for the next MV project which is refurbishing the CUCV 1009 I got from Scrounger's estate. A noticed several of the fittings where the antenna mounting brackets go into the side body sheet metal are either seized up (can't remove the bolts for the antenna bracket) or they spin when I try and remove the bolts. Not sure what these things are called, or where I can get them.
Anyone have any experience with replacing these fittings? The condition of the rear quarters are not too bad, a few creases, not sure if I should cut these out with a torch and replace the fittings, or cut out the entire sheet metal area and patch it with a new panel.
WWRD99
1,942
York Pa
So I have completed my move to the new location, and getting set up for the next MV project which is refurbishing the CUCV 1009 I got from Scrounger's estate. A noticed several of the fittings where the antenna mounting brackets so into the side body sheet metal are either seized up (can't remove the bolts for the antenna bracket) or they spin when I try and remove the bolts. Not sure what these things are called, or where I can get them.
I bought a basic rivnut tool on amazon and used the 3/8 18 rivnut to replace them. Just grind the top ring off the body close, and the old ones will fall out. Very easy to do.
Sent from my SM-S906U using Tapatalk
WWRD99
1,942
York Pa
Here's pics of one of mine. I had the original spots then put a 320 shelter in the back so had to lower it an inch. You can find the mounts on ebay pretty easy. There was a bunch on nos surplus for a while. I bought several. The guard can be harder to find but not impossible. Keep a lookout on marketplace and such. Sometimes they pop up and they don't know what they're for so go cheap.
M813rc
3,955
Near Austin, Texas
As mentioned above, one name for them is rivnuts. Another is nutserts. Pretty easy to work with.
If yours are the front ones on the M1009, you can actually get at the back of them with a long set of channel-lock pliers by reaching up inside the body work from the wheel well. That's how I got the bolts off some that would just spin otherwise.
It was a less than fun experience, but eased by using a great deal of naughty words. Someone with smaller hands would have had an easier time of it.
Cheers
maddawg308
825
Appomattox, VA
Thanks, all, for the info. For the life of me I couldn't remember what those rivnuts were called!
I am torn between removing the ones in place and putting new ones in the same location, or just drilling new holes slightly offset from the original location and putting new rivnuts there.
M813rc
3,955
Near Austin, Texas
Either would work, though the old ones are not difficult to remove. If the holes are sloppy, you can always go to the next size up rivnut.
As mentioned above, one of the important steps for future happiness with rivnuts is never-seize goop on the new bolts. ;)
Cheers
