I had some trouble starting my M1009 yesterday and was wondering how long you should crank the engine. The outside air temperature was ~45F. I have a manual glow plug system installed using AC Delco 60G glow plugs. My glow plug relay is controlled by a momentary toggle switch. My glow plugs are good.
Here is what I was doing to try to start my cold engine:
1. Turn the ignition key to "ON" position.
2. Activate glow plugs for 20 seconds using the momentary toggle switch. (I can hear the glow plug relay click closed when I close the momentary toggle switch.)
3. Release the momentary toggle switch after 20 seconds.
4. Turn the ignition key to the "START" position to crank the engine for about 4 seconds.
5. If the engine doesn't start after 4 seconds of cranking, turn the key to the "OFF" position. Wait 1 minute and go back to step #1.
Is 4 seconds is enough cranking time to start a cold diesel engine? I haven't had a problem using the above method over the last 2 months (September & October). However, it is now November and the outside air temperature is now getting colder. I have never owned a diesel prior o my M1009, and I don't want to crank the engine longer than 4 seconds for fear of draining the batteries or damaging the starter. Any cold starting tips would be appreciated.
Jeff
![Question :?: :?:](https://www.steelsoldiers.com/images/smilies/icon_question.gif)
Jeff
