Chevybrit
- 2
- 0
- Northern Pasquotank NC
HI Guys
Thought I'd start a seperate thread of the ongoing mission to get my M1009 into a great daily working truck.
I want to start with the current problem first and then I'll add some pics later of the things I'd done so far when i get chance..
Ok I had wondered if the truck doesn't actually get into third gear some weeks ago and read up and had some response earlier and still in the process of fitting a tacho but with driving OTR it takes me away for chunks at a time.
I wanted to check the RPMS for that 3rd gear change but something else happened yesterday that might shed some light on the problem. I pulled up in a parking lot and when i stopped it rolled just a little over the tarmac onto to the grass verge... it was about a 2-3" step. I put it in reverse and could get it back up !!!
I read a bit more on here and someone said it could be the vaccum line issue or the governor or low fluid levels.
Ive just checked the trans case level fearing the input seal had gone and it was overfilled.. fortunately its fine and very clean.
I'll check the transmission level in a minute when the truck warms up but i wanted to ask..
Is this where the governor is?
I'd read that when taking the cover off things fly out... is that correct.
I want to check the nylon gear
Thanks in advance
Thanks in advance
