Stratoghost
- 0
- 0
- Belpre, Ohio
A couple weekends ago, I went to Autozone to get some new belts. The belt on the drivers side alt went on fine, but the one on the passengers side was a little tight. I pushed the alternator so that it would slide down the adjustment bracket some more and the positive input terminal came in contact with the bracket (the rubber cover had deteriorated). It immediately welded itself to the bracket and it took several frantic seconds for me to pry it loose. By then I had noticed blue smoke coming from where the alternator had touched the bracket and near my glow plug relay.
I am ok when it comes to working on engines, but when it comes to electrical systems I am not so competent.
When I turn the key, nothing happens. Nothing at all works except for the cig lighter outlet that I directly wired from the battery. The horn doesn't even work.
Here is what I have done so far:
Tested the batteries. Both are new and still good.
Checked all the fuses in the fuse box.
I replaced the glow plug relay.
Found a fusible link that was blown out below the glow plug relay and replaced that and the one next to it.
Replaced the fusible link going to the resistor ? board behind the air filter.
Came here and read a bunch of stuff.
Replaced the ignition switch.
Replaced the starter relay.
Tested the glow plug relay like the CUCV wiki suggested. It goes clunk when it should.
The CUCV wiki stated that if the glow plug relay works but does not work when turning the ignition that the controller board is bad. However, nothing at all works. I would download the wiring diagrams for this thing and attempt to decipher them, if they were available. I think the links may be broken.
There must be some big fuse somewhere that I am missing, or the controller board connects everything to the batteries.
Any help would be greatly appreciated.
